OldTimer
475
Cylinder ID - std = 44.500 ~ 44.515mm service limit = 44.64mm
Piston diameter - std = 44.453 ~ 44.468mm service limit = 44.30mm
Ring gap - std = 0.15 ~ 0.35mm service limit = 0.65mm
Ring/groove clearance - std = 0.02 ~ 0.06mm service limit = 0.16mm
Ring thickness - std = 0.97 ~ .099mm service limit = 0.90mm
Groove width - std = 1.01 ~ 1.03mm service limit = 1.11mm
Piston pin diameter - std = 11.995 ~ 12.000mm service limit = 11.96mm
Piston pin hole dia - std = 12.001 ~ 12.011mm service limit = 12.08mm
Small end inside dia - std = 16.002 ~ 16.013mm service limit = 16.05mm
