Has anyone tried the Pro Circuit Kit (barrel head and pipe) on a Kx 65 yet ?Have tried the dep pipe but powerband to narrow and very revvy - also V FORCE Reed Block on same bike - any body got one yet! ;)
What year is your KX65? The stock 02 pipe is much improved and the port timing is way different. Kaw raised the exhaust a bit and reshaped the downward angle of the lower intake port.
Overall the 2002 is much improved in stock form. For the 2000 & 01 models, the problem is in the cylinder porting. The transfers are too large so the aftermarket pipe manufacturers focused on rapid evacuation of the cylinder. That should help the mid range on the older models.
Regarding your DEP pipe, maybe you ddn't jet it rich enough on the slow jet, that could account for the lack of low end.
If anyone has experience running the Pro Circuit kit, please give this member the info he's looking for.
Thanks Eric bike is 2001 and I have not altered slow jet - The Bike has stock jets - any reference to jetting would really help But I know how difficult than can be but a starting reference would be great.
