fishhead
die you sycophant !
966
Well I was just about to spring for a ttr 125 for my son and he bummed a ride on a friends kx80 and a rm80 and thats what he wants now. I've not followed the mini scene much but I've narrowed the selection down to a kx or rm with the kx being in the lead by virtue of my familiarity with the kayaba suspension and the kawi link.
I'm going to consider a preowned unit so I'm hoping someone/ anyone can give me a bit of a rundown on the model year changes and give me a heads up if there are any dogs in the pound. I'm going to look for a recent model with the inverted forks for sure. It will be for offroad use so I plan on a flywheel weight and springs and valving for his weight and conditions plus cleaning up the jetting.
Thanks in advance for the help.
Chili
Apr 9, 2002
8,062
17
My son has raced a 99 KX80 for the last 2 seasons and we have been happy with the purchase. We went changed the gearing from 14/50 to 13/49 and went to some low tension carbon fibre reeds from Carbon Tech.
The only problem we had was right near the end of this season we had the pin that holds the powervalve snap right after a fresh rebuild. This of course resulted in taking out the new piston and scoring the cylinder. I learned later from Eric and Rich that this is a fairly common failure on this setup and changing that pin during a rebuild would be a wise step.
Midhigh
481
My son ride the 2001 KX 85. It has been a very good bike. I changed to front sproket from 14T to 13T. The KX is a little more beginner friendly than the RM. My son really likes it.
KelvinKDX
1,622
Originally posted by fishhead
... It will be for offroad use so I plan on a flywheel weight and springs and valving for his weight and conditions plus cleaning up the jetting.
If he is using it for off-road use and not racing in any cc class - you may want to look into the kx100 too.
fishhead
die you sycophant !
966
the kx100 is a bit taller than the kx 80 since the wheels are larger. a few guys run kx 100 top ends on kx80/85 bottoms in the local super mini class and some run the 2mm overbore setup.
drk98
358
Now you can get a RM100 if you wait for a used one.
I got a '97 RM80 instead of a TTR125 and I'm glad I did. Weight was plentiful and power was lacking in my opinion. And now it has electric start????? The RM has good low-end power right after the KX. If you are riding lots of trails he might like the 100 ported for low end power(what I was going to get instead of my KDX). Whats he weigh and how tall is he? I'm 5'6", 140 and the KX100 fits me good.
fishhead
die you sycophant !
966
he's 90lbs and 4'8" not quite ready for 100cc power but growing fast. not at the age where the big growth spurt hits boys. its a couple years away
Martin Cole
66
We've run a full season's MX on a KX85 (big wheels) and not had any problems until last week. It's 2001 bike and did two successful seasons before we bought it. The previous owner left it stock except for a 51t rear sprocket for more pull out of the corners and a Pro-Circuit pipe to strengthen the mid-range.
Last week it started making odd noises and we suspected the crank wanted rebuilding. It was just about at that point but the noise was a seized water pump bearing-so its had the full rebuild anyway.
While it was stripped we noticed the power valve wasn't opening fully. They can get carboned up - so need to keep an eye on that.
Also - power valve actuator can fall apart and create a lot of damage in the clutch casing. The answer, we are told, is to overfill the oil level. It should take 650ml but most people reccomend 700 or a bit more. For best performance change piston and rings around every 12 hours racing use.
The KX seems fairly robust to us and my son loves riding it. It handles well and has good brakes. We are pleased we bought it.
pyrofreak
819
CR85r:
Goods:
improved power from extra displacement
excellent gear ratios, shifting
effective, highly-adjustable suspension
Bigbike front disc brake, super-powerful
good balance between cornering, stability
unequaled durability, ease of maintainance
Downs:
bar bend old, changes with crashes
chain wears out too quickly
suspension on soft side for experts
seat/tank junction snags right boot
clutch fades when abused, no AOF
KX85:
Good:
Excellent turning, handling
great clutch action, light pull
Easy to flick around
smooth power delivery
great beginner/ novice mount
bad:
suspension holds back fast ones
so does the midrange motor
heaviest bike in class
pocket in seat restricts movement
gastank inlet too small for quickfills
rm85:
good:
best clutch, slick shifting
smaller, lighter kids dig shocks
more low-end than yz, cr, kx
lightest weight in class
flat tank/seat junction
bad:
Lacks top end power
fork too stiff, shock too soft
cheesiest graphics in class
slowest turning, some shake
steel brake pedal
yz85:
good:
most top-end power, good bottom/ mid
excellent suspension balance, action
excellent turning, stability
good bar bend, skinny ergonomics
great package at lowest price
bad:
Cheesiest chain stretches quickly
clutch weak, need adjust on the fly
tall seat height for shorter riders
power delivery erratic for neophytes
Ergonomically Correct
1:Yz85..............Thinnest
2:cr85..........Wide, Catch Boot
3:rm85.......Tallest, swept bars
4:kx85........Seat pocket
Fork Facts
1:yz...........Tuned for speed
2:rm...........Stiff
3:cr..............stiffest
4:kx............Softest
Shock Jocks
1:yz...............perfection
2:cr..............stiff but good
3:kx..............soft but good
4:rm.............to soft for most
Suspension sensations
1:yz..........Best balance
2:cr..........best expert
3:rm...........imbalanced
4:kx...........beginner/novice
Peak Ponies
1:yz.............22.7
2:cr.........21.8
3:rm............21
4:kx..............20.7
power spread
1:yz...........widest spread
2:cr.............soft low
3:rm...........all mid
4:kx.............no top
Turning Tables
1:kx............mindreader
2:yz............wired into CNS
3:cr............stiff fork
4:rm.......... stiff, sedated
Stability at speed
1:yz.........no headshake
2:rm.........imbalanced
3:kx.........headshake
4:cr.......... headshake
Clutch
1:rm
2:kx
3:yz
4:cr
Brakes
1:cr
2:yz
3:kx
4:rm
Best beginner/ novice
1:kx
2:rm
3:yz
4:cr
Best expert
1:yz
2:cr
3:rm
4:kx
Overall
1:yz
2:cr
3:rm
4:kx
drk98
358
He's 4'8", oh, then you might get a XR100 if he is pretty "timid" or isn't real agressive and doesn't jump a lot.
But you might go ahead and get a 80 anyway. The 80 will prepare him better for his next bike(especially if it's a two stroke or he is going to race). What does he ride now? I rode a PW80 before my RM80.
I read that test pyrofreak posted in a magizine not to long ago. They put too much down on the bike if it isn't perfect. The KX and RM are last over all but you go to a race and that is all you see.
But, like it says the KX and RM are beginners and the CR and YZ are for experts.
Chili
Apr 9, 2002
8,062
17
Pyro all that data and most other magazine spewed tripe is of little use in the real world. I think that all the bikes nowadays are getting so good that there is so little difference especially in the 85cc class. For reference your data shows the YZ as the best Expert bike as well as the Best overall 85cc bike, our top 10 for points in our premier 85cc class here went as follows this season.
1. KX
2. CR
3. CR
4. RM
5. KX
6. KX
7. KX
8. CR
9. CR
10. KX
You had to get to 11th before you saw a YZ. And before you assume we have no Yamaha dealers here they outnumber all other brands of bikes for dealers in my city.
Bottom line is they are all good bikes, get the one that your most comfortable with and like the dealer the best!
fishhead
die you sycophant !
966
The xr100 was on the short list with the ttr125 till we went to the last Hare Scramble and I saw how much more aggressive he'd become in the last several months. The 80 class bikes are a lot lighter than the 4strokes and they all have much better suspension so he will have to learn some throttle control but I don't see that as big a problem since I'm commited to riding with him on the easier terrain till he gets his skills up. The rm and the kx seem to do much better in the woods from what I've seen since they have power valves and made a bit more low end power although the magazines don't see it that way. The yz and cr seem to fall off the pipe more readily from what I've seen on long grades up switchbacks and the like. A ttr125 powerplant in a yz80/85 chassis would be ideal but I'm not into 10,000.00 and serious shop time to concoct a frankenbike or go the bbr route. However if a good rolling chassis came along I might rethink the deal but I'd rather ride than build bikes.
A super mini chassis and a clean running 4 stroke covers a lot of bases
drk98
358
I don't know if I'd call the TTR a power plant! LOL
Does he want a 4 stroke? He'd really miss out on fun and expirence if you got a TTR. If I had got a TTR and hopped on my KDX I'd be lost.
I was scared of the power band on my RM80 when my dad told me about it like it would make my bike flip. Hey I didn't know when I rode a PW80.
It's not that hard to ride a 80 in the woods. In fact the power can come in handy once in a while.
We put a 12 tooth instead of the 13T that was on my RM and changed the gasgets to get more low end.
DEANSFASTWAY
1,192
Fishhead The KXs are pretty reliable as long as you like touse good oil and gas at like 32;1 and dont run it out real lean , The crank likes oil.. The powervalve linkage has been an issue and theres a bulletin from Team Green on it some are assembled too loose and the governore balls fall out . Ive seen it on a couple of bikes . Youll also want to run the new for 04 spring loaded P/V link (cheap). The transes are pretty strong and pretty durable. The frames can break under the gas tank junction but only if a real fast or heavy rider or a jumper, we were gusseting them at the area and it stopped . The kid was like 125 lbs. One frame broke so bad it pulled the cyl studs out and cracked the cases near the swingarm pivot . KAW warranteed the parts.Now hes on a 125
fishhead
die you sycophant !
966
Dean,
Thanks for the tips. prices are pretty soft right now on the kx85's so we might go new. Does any one know if there were any motor changes '00 to '01.
Solid State
492
I am planning on a top end rebuild for an '01 KX85 now that its been getting cold. Aside from the usual top end service (piston, rings, clips, wrist pin, wrist pin bearing, gaskets, de-glaze cylinder, clean power valves) what other parts should be replaced given your experience? The bike has never been run hard and this is the first top end. Please explain the P/V linkage issue and the need for the '04 spring loaded P/V link. Do any of these parts issues need the bottom end opened?
Thanks.
DEANSFASTWAY
1,192
Solid State I really cant link the bulletin to you but you could see it at Team Grren website or Team Green news Theres alot of helpful tuning tips there also.Theres a spec of how the P/V governor is pressed togethjer when built at factory . If a cup isnt pressed on all the way the gov balls can fall out. the new inkage part that comes up out of the case has got like a spring dampener on it that can help keep the P/V from slamming open or shut so hard . This wears out the governor and parts. The bearing in the gov assy can be replaced if wqorn out for like $5.00 at bearing house. The governor assy is expensive at like $ 65.00 or something . If you look at buy Kawasaki .com parts micro look at the different years of parts. You may want yto take a peek at the reeds while your doing a T/E . Sorry my typing not too good tonite. GLMF
Solid State
492
Thanks for the tip about the reeds. I was planning on taking a look at them. I went to the Team Green news website. It seems to be Canadian based and I could not find any service bulletins (they did have a pdf on race porting - wonder if Eric G. has any comments). I also could not find any other Team Green web sites. If you get a chance, could you post the name of any website that might lead me to the info?
Smit-Dog
4,704
Hey Fishhead -
Just wondering how your son did with the KX-85?
I'm in a similar situation... here's the deal:
1) My son is turning 10 in a few weeks. He's 4'8" and 70lbs. Slightly tall for his age, but thin and lanky.
2) Coming off an XR-70. Previous to that he was on an XR-50. I'd like to get a bike that lasts more than 1 year.
3) We ride strictly off-road, woods, trails, single track. The trails have a fair amount of sand for a kid.
4) He's not a super aggressive rider, but is cautiously improving his riding skills.
5) Watching him ride from behind on the XR-70, I think the smaller bike, small tires, low-footpegs, and hunched over the handlebars standing up is holding back his skills somewhat. He is definitely ready for a new bike this season.
I too have looked at the TTR-125 (small wheel version). The bike fits him great, but at 176lbs, it weighs 50lbs more than his XR-70! Also, I want to wean him off the tame power of small, heavy four-strokes, but there aren't a whole lot of small, woods-friendly 2 stroke choices out there.
Seems like the KX-100 can be made into a great woods bike, but it is just way too big for him (we tried one on for size last weekend).
I have the opportunity to buy a used, recently rebuilt 2000 KX-80 that has KX-100 cylinder on it. It's been ported and tuned for a woods-friendly low-end powerband. It also has KX-100 wheels on it, so essentially it's much closer to a KX-100 than a KX-80.
My son threw a leg over a KX-85, and while somewhat tall, it was doable. The great thing is that it's only about 15lbs heavier than the XR-70, 11lbs lighter than an XR-80, and a whopping 33lbs lighter than a TTR-125.
If your kid's experience with the KX-85 has been good, I'm thinking about getting the hybrid KX80/100, and putting the smaller KX-80 wheels back on it. When my son is tall enough, I'll put the larger KX-100 wheels back on, and presto, he has a larger bike to ride for another year or two.
fishhead
die you sycophant !
966
sounds like the best plan to me.
I haven't pulled the trigger on the kx over the winter since they grow so fast and its beeen cold and wet but the kx80-85 to 100 is a great option. My son is not agressive until he gets in a group so it will take some time on the open stuff to get him up to speed. Ididn't think the wet roots and mud would be the best way to start him on the 2 stroke. The most tell tale sign is when they are riding past the bikes suspension capabilty. Thats where we are with the xr70 and the 4 stroke options are cheesy in the supension dept. A cr80 xr100 hybrid would be great since it would fit him well and give him better supension.
The kx 85 100 difference is basically the jug head and wheels from what I see. The 100's are plenty peppy my freind put a throttle stop on his sons 85 for the frist month or so till he got some seat time. I did some calculations on power and weight and an 80 lb rider on a 85 is about the same as an adult on a 250. I'll opt for a flywheel weight.
The kx has the easiest suspension to lower and best woods friendly valving stock.
FRESH VIDEO
