Well, finally pulled apart the boys 2000 KX80 to see what failed.
Third connecting rod big end bearing failure in a row. the original, a factory crank assy and now a hot rod kitted crank.
what is the primary failure mode here? imbalance? bearing damage at assembly, poor materials? everything looked fine each time.
i would like to build it backup as a supermii spec motor but its not even making the 10 hr mark right now. i hear is is a weak link. what about a KX85 assembly?
jetting appears ok, no air leaks, no sign of dirt getting by. nothing different from last year, same lube (maxima superM) and ratio 32:1.
thanks.
thanks.
