YZThumper said:The manual says to line up the punjab marks on the two transfer port valves with marks on the actuator rod. However, I've found this doesn't always allow the transfer ports to be completely open. I line up the punjab marks on the transfer port valves to the marks on the actuator rod as my starting point. I then look inside the exhaust port while pulling the actuating rod out, and you can see if the transfer port valves allow the transfer ports to be fully open. If the transfer ports are not fully open when the actuator rod has been pulled out, I pull the transfer port valves up out of the cylinder and rotate them one tooth on the actuating rod. \QUOTE]
Thank you YZThumper.
That was the problem we encountered. The transfer ports were not completly open. I wound up going by the wear marks on the transfer ports and re-setting the gears to match.
Thanks again. :cool:
