directional
44
Well I blew my top end because my coolant pipe ripped but to get to the point I have to order a new piston
I noticed on motosport that they have a .020 overbore piston that will fit my bike.
How many more CC will this give me? Will I notice a good difference? Any suggestions?
Thanks..
ThormxKid
16
its not going to give you any more power do you know how small .02 of an inch is. i would just ball hone it and rebuild with standard size piston and rings
directional
44
that's why i was asking.. it didn't seem like a lot of size difference.. .020" is a half a millimeter...
maybe i will give eric gorr a call while I am at it .. im just not sure if i can go without riding for 2 weeks.
IndyMX
Crash Test Dummy
5,548
Amo, IN
If you are almost certain that there is no noticeable benefit, but potentially quite a bit more work involved, why would you do it?
And if I am not mistaken, isn't honing done to finish off a cylinder after a bore, or to clean up a cylinder that's in spec but used?
How are you going to be able to tell when you are .020 over with your hone?
I would suggest that you either use the proper spec piston, or send it out to a capable machinist to have it worked on.
Most likely you will end up spending quite a bit of cash otherwise.
directional
44
Okay well thats why I posted here to find that information out :)
I will order the standard bore and just hone it out to clean it up :D
TY
