so the problem is that it wanders up and down? or does it die? The only other thing that might be leaking is the left crank seal, but not likely. Usually if these leak, over time you will be able to see stream of residue behind the ignition cover, running out from underneath/behind the stator and flywheel.
Some bike idle smoother than others, but you ought to be able to get it decent. Usually if the pilot jet is in the ballpark it will die down/load up pretty quickly with the air screw all the way in, although it might not die instantly.
