dunno00
6
Leaking gas i have a 1999 yz125 and when i turn the fuel on it leaks gas really bad out from one of those little tube that runs down below the engine.. i mean a constant flow but when i ride it it doesnt leak and as soon as i stop it leaks again....now im only 15 and know only a little bit about my bike im learning tho..if anyone has any advice it would be greatly appreciated.
nickyd
873
you'll need to pull your carb and clean it. could be as stupid as piece of dirt in the needle seat. or your float could be off. if it just suddenly happened, pull the carb, remove
the float and needle and clean it. i bet it solves your issue.
