- Feb 5, 2007
- 60
- 0
I've done quite a bit of searching over the internet and havn't really found a comprehensive list of information to include pictures of the LHRB setup. So, I'll have one up pretty soon. I recently picked up a 10.5 Magura M/C, and then ordrered a brake cable from Rekluse that will fit my bike and goes with his LHRB setup. If you need a cable, go to Rekluse. He gets them from Speigal, and gets them to you for a better price thatn what you can get directly from Spiegal.
As for the Dr.D Hotstart kit (moves the hotstart button from the side of the carburator to the handle bar), I found some info on people using Honda CRF cables, and monkeying around with getting the cable to not stick out so far from the bike. The best setup I've read about, and seen pictures of is the Dr.D setup. I called Dubach and talked to them about a plan of using my Decompression lever with their cable. The Dubach gal stated that the cable by itself was about 20 bucks, but then you have to get the plunger that goes into the carb and into the cbale. Well, that piece only goes with the "Kit", which is sold for about $85 (RockyMountainATV). So, after looking at my Decompression lever and thinking about it, I decided to put the money down on the Dr.D (Dubach) Hotstart kit. I've read that this is critical when in a race or doing a Hare Scramble, essentially it makes the differnence between finishing 3 or 4th and dead last.
So, just wanted to let you all know, just as my write up on the Rekluse Clutch install, I'll have another couple of write-ups coming on the Dr.D Hotstart kit and the LHRB setup.
Post up if you all have any questions....
