lime away
12
Has anyone adapted a plate to a stock ('99) rear fender that looks decent? I just don't want to bend it around and zip tie it.Is there an aftermarket holder that doesn't come with a tail light? Thanks.
DENNY
218
UFO makes 2 styles of universal tail assemblies and depending on your needs the main difference is size. The larger version is good for dual sport conversion and the small one works good for enduro races. I've used both and the only problem is the cross bracket on the sub frame prevents you from mounting it underneath. On my KDX I removed the tail light from the fender and mounted the UFO tail piece on top of the fender. It truely doesn't look bad and if you want I can post a photo?
