where and what kind of bulb would i use on a head light and tail light from a 82 kdx 175 i was missing these two things otherwise i am complete. thanks alot for any info.
Been a long time since I looked for a 175 headlight bulb, but I think it is the same bulb used in some lawn tractors or tractors. I am sure someone or the manual will tell you the specifics on the bulb.
As for the tail light, an led bulb is the only way to go because of vibration. You can usually find them now from some of the led web sites. You will have to know the correct base and voltage, but again you can find that from the manual.
