Warren78102
My 2003 Yamaha 250f loosing fluid out of the radiator, I have had the radiator flushed. The only place I can see if some fluid comes out of the big hose coming out of top of the head.
Matt90GT
1,517
If fluid is coming out the vent hose in the valve cover, means you have a cracked head.
Clean the bike, run it and inspect for leaks. If no fluid is leaking externally that you can see, you have a blown head gasket or cracked cylinder/head/case
YZ__rider
152
Make sure you are tracing the correct hose...are you sure it isnt coming from the radiator overflow?
Is it actually leaking from the head? If so, get ready to pony up some cash and/or alot of your time depending on the culprit.
If its pushing it out the overflow, consistently, all the over flow bottles in China will not help it. Its not a trail bike, it will push out excess, after a top off, but thats about it, never again. Vintage Bob
ellandoh
dismount art student
2,958
do rickshaws have coolant??
Warren78102
The coolant is comming from the hose on the top of the head. I have tighten the head bolts. It will go a 5 lap moto and loose some fluid but not get real hot. There is no water in the oil.
My sons worn 450 would build a small residual amount up, it appeared like milk, maybe a few drops. A steady amount after warmed up, back to the gasket or cracked head. A leak down test or coolant system pressure test should show the issue? Or, it sounds like it has been doing it for a while, a tear down should show where its been leaking at? You do have a bike with a pretty strong valve train, BUT, bet the rings are gone anyway. Time for a top end and bottom end inspection and measure everything. I have seen pics of a rickshaw before, never one with coolant, but the operator may require coolant, frequently? Vintage Bob
YZ__rider
152
Regardless whether it is a bad gasket or cracked head, you will need to pull it apart to find out. When you are in there, you may as well rebuild the entire top end if you plan on keeping the bike.
