Guys and Gals,
After reading through some of the posts today I thought that is was time to discuss some maintenance tips.
New Bike: Bring it home, dump the fuel, drain the oil. Then start tearing it down and grease all of the bearings, links, pivot points etc. Buy a can of ANTI-SEIZE and use it on every nut, bolt, screw.
Even brand new there is basicially no grease in the bearings, and without lubrication the bearings will corrode and fail. The anti-seize helps to prevent galling and stripped bolts/screws.
If you bought a used bike do the same thing except it will probably take longer because you will find something wrong or parts that need to be replaced. And after a while of ownership repeat the process as neccesary.
At the end of the midwest riding season all of my bikes go into the basement for major maintenance i.e top ends, tires, lubrication. I have five MX bikes that I need to maintain, and every one is torn down, parts replaced, lubed and prepped for the next season. If you are experiencing rusted or hard to remove nuts and bolts then you are not MAINTAINING your bike, you merely own and ride one.
Racing/Riding on the weekends is the FUN part after the WORK and MAINTENACE has been done during the week. I am trying to impress this concept onto my kids. There is no FUN without some WORK.
Just my 0.02 :aj:
Just my 0.02 :aj:
