newatthis
7
I am not a small engine mechanic, but I am trying to put a 26mm mikuni carb on a KLX 110. A couple of questions:
1) The foam air filter that comes with the kit is mounted directly on the carb, and should be oiled prior to use. Is this correct?
2) Where do I connect the fuel line to the carb? There is no connection in the same place as the stock carb. The place where I think it goes has a smaller connection than the stock carb.
3) The petcock must be plugged. I open it and no fuel comes out with a tank full of gas. How do I clean this out or should I replace it?
Thanks in advance.
