HajiWasAPunk
- Aug 5, 2005
- 807
- 0
Ok, so after a couple of lessons here's what I've believe I've learned correctly:
1. I should be standing up on the balls of my feet unless I'm in a turn with legs straight but not locked.
2. my head should be over the handle bars (so I can read the number plate if I looked down) and it should move little to none between standing and sitting.
So how do you shift gears then? You have to move you foot forward right? And to brake (though this seems less of a problem since I'm learning to rely much more on the front brake)?
