my cr80r wont idle at all!
thejake456
219
i've been having trouble with my bike not idleing. i tryed adjusting it but it wont make a difference? it is like you almost have to have it 1/4 throttle to keep it running? i tryed cleaning the carband the reeds. i am in the process of a rebuild! could that have been the problem???
Patman
Pantless Wonder
It's not going to sit there and idle away like a CRF50.
Patman
Pantless Wonder
Your first post would indicate otherwise.
thejake456
219
it seams like if you have it from no throttle to 1/4 throttle it will shut off and when you give a bike gas it should rev up.
p.s sorry for the lack of explaining!
Dylan19302
111
I have a 1982 CR 80 I have to hold the choke up for about 1 minite before it will idle on its own. When you cleaned the carb did you take out every jet and clean everything because 1 little grain of sand could block something.
I also have a manual for my CR 80 and for the airscrew jet
the 81 is 2 turns out
the 82 is 1 1/2 turns out
the 83 id 1 3/4 turns out
the 84-85 is 1 1/2 turns out
Also is your throttle cable adjusted right. It could be too loose.
Cookies are required to use this site. You must accept them to continue using the site. Learn more…
