Blisterphish
- Jul 15, 2006
- 27
- 0
I purchased a well-used 96 YZ 250 at the beginning of the summer. It has always sputtered a lot at higher RPM just after starting then idles poorly after warming up. It kills very easily and kick starting is a #$&!
Last week I went for a quick ride and got about 500 yards before the bike began to make a very throaty sound and died. The sound was the same as if you had the choke on and hit the throttle…..kind of a hollow sound.
I grabbed the Clymer book(after pushing it back home) and began troubleshooting. Here is what I’ve done so far.
New Plug
New Plug cap
Tested Coil resistances – Good
Checked all electrical connections – Good
Checked Stator Coil resistances – Good
Pulled the carburetor and completely disassembled and cleaned it.
Set Jet Needle to the #3 position, which is stock. Someone had it set as lean as possible #5. I don’t know why. The jets are stamped with the stock numbers and did not appear to be clogged.
Flywheel was rusty and filthy and the stator coils were very dirty so I cleaned them all before reassembly. I figured that was the problem but no dice. I can smell fuel and the spark plug is wet after I try to start so I know it is getting fuel. I had just cleaned the air filter and the box looks pretty good so it is getting air.
I am to the point where I think it must be the CDI unit, which costs about $120 or something completely different. I’m hoping some of you have seen this before and can put me on the right trail before I start throwing hundred dollar bills a this thing. I'm at a loss... :bang:
Thanks in advance,
Dave.
New Plug
New Plug cap
Thanks in advance,
Dave.
