XtremeAir125
- Jul 5, 2001
- 120
- 0
Ok, here's the deal. My bike falls flat on it's face when it hits into the high rpm range, I bought Eric Gorr's Motocross Guide and it really helps me a lot. I also have a YZ125 that I love but those Yamaha parts are expensive!! Anyway, my bike has a FMF Fatty Pipe w/PowercoreII Silencer, and RAD Valve w/Carbon Fiber Reeds. I read in his book to get more top-end you should add "exhaust valve plugs" made by Boyesen Performance, but I emailed Boyesen and they don't make them :think ?? The plugs are made to be installed in place of the HPP valves. The plugs are installed in place of the HPP valves. The exhaust port height can be raised to 28 millimeters measured from the top of the cylinder. That will really make the engine rev. And it says, by removing the exhaust valves you can also remove the powervalve governor that drives off the crankshaft. That serves to reduce drag and friction on the crank and yield an extra horsepower. Can Eric do all that work for me? I know my gearing doesn't have much do to with it really but I have a 51 tooth rear sprocket, would a 50 help more? Also, a 90-96 CR250 carb would also benefit, I'm currently looking around for one. I'm probably going to get it ported with the "Mo-better Everywhere" style, and possible a 133cc over the winter. Would a 95 cylinder head be worth it too to throw in? I just wanna get this bike as fast as I can. Thanks guys!
