I have to order a 40 pilot and that should (hopefully) finish my jetting adventure. Since I have to order the jet anyway...
Can anyone make a good recommendation for a new needle? I'm using the stock needle right now, and it looks like my jetting will end up with 152 Main, 40 Pilot, needle in 3rd clip, AS=1 turn out.
I've read that the right needle can really change performance, even give a stronger "hit" than the stock needle does.
I suspect there is no "right" recommendation and that the optimal needle is based on a lot of things; what do you run in your bike?
