1st- what is the switch on the front left side of the engine? Looks similar to a fuel cutoff.
2nd- should i have a mikuni carb or a kehnin? I have the later.
3rd- why does my engine stall sometimes (mainly when cold) when i shift into gear?
4th- It doesnt idle very good after i shutoff the choke but if you take up the slack in the throttle it will smooth out, normal???
5th- can you shift gears without using clutch (seen on another thread and made me wonder)???
6th- how much oil should be in the gear box?
