srellis
394
Yeah, I forgot to mention mine is ridden by a little ole lady on Sundays!!
Here lately it has only been 10 to 12 miles per ride. MX only. At first I was putting in 30 to 40 per ride with hare scrambles but that season is over until Fall.
SusanE
canyncarvr
4,005
I didn't impugn anyone's ride or any rider. Maybe you're a '..little ole lady..' maybe you are just a 'surprised woman.' I have no clue, and it is of no particular import.
I'm looking for information on this particular bike...what is reasonable to expect in areas of longevity and 'normal' wear.
If I had to put a top-end (that to include headwork required on a 4-stroke) in a bike every 60 hours, I'd be very unhappy about it. We've put that amount of time on bikes within a couple of months, easy..and while I don't mean this as some phallic issue (we be ridin' faster-harder'n anyone ever!), I wouldn't say we exactly poke around, either.
It's helpful to know when 'normal use' is mx, when it's woods. I doubt the bike Mr. Rohrich refers to has a lot of woods use on it. He didn't say.
TreeTalker
161
I got my bike back in march and I have put many miles on it. On average I put 35 to 50 miles on it once a week when I hit the trails or fire roads. Now it does use some oil but not much. I usually have to add about half a quart between oil changes. And I change my oil every 350 miles due to the dusty conditions I ride in. I also clean the air filter when I change the oil.
As for any problems, only one so far. A lower seal on the front fork started to leak the other day. Cleaned it out and have had no problems since. I keep the chain clean and lubed before every ride. I just had the top end checked also, no problems there either. So as far as long term goes I think this bike will hold up just fine.
Now as far as the power and the ride quality of the bike. I could go on and on for hours on that subject. Let's just say it has more power than I will ever need. (just your average older joe here, I don't MX) The suspension feels great on this bike. I usually ride 5 to 6 hours at a time, and I don't feel wiped out after the ride. Now I am not riding race speed on those long trips though, but not just putting along either. I love this bike on trails, it's like it can read my mind. It corners like it's on rails. It climbs hills in any gear without ever acting like it wants to stop and take a breath. So I can't complain about the bike.
The only the I have done to the bike is sand down the seat cover. I hated having a chaffed ass after my long rides. I left about 3 inches of nobs on the back just in cases I ever started to slip to far back. I also just put on some bark busters and a Devol skid plate.
I have wrecked this bike plenty of times and so far no major damage. I had a bad wreck the other week on it. Ran into a tree pretty hard, and did no damage to the bike. Just had to re-adjust the front fork.
Well hope this helps you out if you had an concerns about the bike. I am 6', 175lbs also. Good luck with your search for a bike........Lee
canyncarvr said:
How much of this is relative to level of use and how much is difference in bikes?
It's tough to say for sure but here's what I can tell you from what I have seen.
- all single compression ring pistons use more oil than designs with two compression rings. The second compression ring works as much as an oil scraper as a compression ring, so when it's not there you lose it's ability to scrape oil from the cylinder wall.
- With only one compression ring break-in becomes more critical. If the one ring seals poorly the heat transfer and oil control will be poor. This will make the engine use oil and lose compression VERY QUICKLY. These are fairly low tension rings to start with so ring to wall seal becomes crtical.
- The pistons are incredibly short skirt and will lose their ability to stay round after they have some time on them. Pistons that measure to spec aren't necessarily OK if they have a lot of hours on them. Once again with only 1 compression ring you have to pay close attention to everything involved in the ring sealing chain. Fatigued pistons and poor crosshatching during replacement will lower performance and increase oil consumption.
- The intake valves are titanium with a thin hard coating over the valve face. The valves can't be lapped as a result so once the valve seat goes out of spec the valves have to be replaced . Springs generally need to replaced at the same time .
- We've seen a couple of examples of the seat width doubling after about 50 hours. This means the seats need to be recut when replacing valves to bring the seat width back into spec. The seat material on the 250F appears to be much softer than the CRF450. This should help valves last longer but it may increases the need to cut the seats. Not enough data at this point to know for sure. We are keeping a close eye on this.
- Kibblewhite is working on replacement stainless steel valves as well as a higher grade spring kit but at this time they aren't available. This is the standard fix for CRF450s and provides exceptional long term reliability on these engines with no loss of performance.
This is a really nice engine design but don't mistake this for a trail bike. This is a serious racing engine and will have maintenance requirements that reflect that. Guys who just poke around in the woods should get longer life out of the various components, but don't for a second think it will last as long as an XR or KDX before you have to pop the top and do some reall maintenence.
I hope this helps. As Eric and I gather more data we'll pass it along. Mike Perry, R&D Chief from Kibblewhite has also been really helpful in sharing their experience with customers as well as their in-house test programs.
Tomck
Rich,
Good information in your post. I have followed the discussion on this bike with some interest on Thumpertalk, and you made a key point:
"This is a really nice engine design but don't mistake this for a trail bike. This is a serious racing engine and will have maintenance requirements that reflect that. Guys who just poke around in the woods should get longer life out of the various components, but don't for a second think it will last as long as an XR or KDX before you have to pop the top and do some reall maintenence."
I can understand that people who race want to obtain all of the power available, and additional maintenance is an acceptable compromise, but I would be hesitant to buy the CRF250X, even though most reviews say that it offers outstanding handling/suspension. It would be great if Honda would also offer a detuned, trail-oriented version (two-ring piston, etc.) designed for less maintenance.
TreeTalker
161
Well crap, and I thought I would have a bike that I could just ride without worry as to it breaking on me.....Man you guys sure know how to make a guy feel bad...lol Oh well guess I better start looking for pennies on the trails.
Thanks for the great info though, at least this way I know what to expect.
jcramin
190
My first ride on my CRF250X was 44 miles and I too had the right fork seal leaking and it leaked enough to put a pubble on my garage floor by the next weekend.
Once that was FIxed and got to really ride it after breaking it on WOW I love this bike. Im coming off of a 98 CR125 and I didnt know what suspension was supposed to do on a trail ride untill I got my X now I see why my CR125 beat me up everytime I rode it.
Ill be going to St Joe State park Wed March 26th and camping and riding for 4 days with my wife. Ill probably put a few hundred miles on my bike that week. It only has 77 mile on it now I cant wait to be able to ride it 4 days straight all I want.
canyncarvr
4,005
Re: detuned
The -x was introduced after the -r, right? Other than some basic stuff...differences in headpipe length, transmission ratio differences, wheel sizes......are these two engines largely the same?
....disregarding the camshaft differences. OK..guess the differences are a bit past basic.
So, in regard to what Mr. Rohrich referred to....they are the same? Same piston, ring, valves, seats and such?
Knobbyjake
203
Rich, would the Yamaha WR250F also fall in the category of not mistaking it for a trail bike? Is it as high maintenance as the X or is it more trail tolerant?
JasonJ
1,150
I too would like Rich's 2 cents on an overall maint comparison to the WR.
Also, how much dose a valve job cost?
Wouldnt Stainless steel valves be heavier than Ti thus possibly throwing the balance off and slowing the rev rate?
What kind of break in do you adhere to for this bike?
Ive been waiting for a 250 4 stroke trail bike with enought grunt to replace my 99 WR400 without leaving me feeling underpowered. Maybe its time to go red?
JasonJ said:
I
You can pull the cylinder head and top end yourself and any good performance shop can take care of cutting the valve seats and assembling the cylinder head properly with the springs set at the proper installed heights. Dealerships seem to lack the equipment and personnel to do good work on these performance oriented engines. It's understandable when you consider that it costs about $30,000 to get up and running with a Serdi valve seat machine.
Most shops get about $25 per valve for a valve job. A valve job will often times be necessary if the valve is badly worn and has compromised the seal at the seat. Some shops charge extra for the assembly/disassembly process some don't. Most will have some sort of package deal on labor if you buy valves and springs through them.
The stainless steel valves weight a bit more and there is certainly some basis to the theory that stiffer springs will increase the frictional losses at high rpm, but after a lot of testing I've yet to find it a measureable difference on the current crop of MX four-stroke singles. Along with a lot of testing with customers I've done a ton of research through SAE publications on the subject of frictional losses in high speed engines and have come to the conclusion that while frictinal losses do increase with stiffer springs in a test stand motored engine, they appear to be more than offset (at least in the case of MX singles) by better valve sealing as a result of limiting valve bounce at the seat as it comes off of the cam's closing ramp.
When new, these engines will break in nicely on a couple of easy 15 minute heat cycles and then running them fairly hard. Oil changes after each heat cycle seems to be one of the most important parts of all this. The rings seal almost immediately due to the honing method used by the OEMs. The heat cycles are mostly to allow the crank , rod and main bearings to bed in.
The YZF/WR250s don't require rings or valve replacement as often as the CRF250 but the Yamaha 250F will break the valves and the cranks if you let them go too long. Occurences of this type of destructive failure are far from isolated. Now that the bike have been out there riunning for 2-3 seasons these things are breaking valves at an incredible rate. The guys who seemed to get burned by these failures tend to be second owners who don't have accurate recoreds on the maintenance the first owner perfromed.
This type of failure can happen on the big YZFs but it is much more rare (so far). Given the number of catastrophic failures I have seen on these engines I don't have a whole lot of faith in the two piece OEM Ti valve design or the quality of the OEM springs. All the YZ250F & CRF450 engines we build get one piece stainless valves and the appropriate upgraded springs as replacements for the OEM Ti valves, and we highly recommend them on every YZF4xx we work on . We use Kibblewhite valves and springs exclusively for these engines. As a result we sleep easy and so do our customers. Piece of mind seems to have that effect on folks. ;)
I've yet to see a CRF 450 break a valve this way even when they are hammered to the point of barely sealing. It remains to be seen if the CRF250 will shed parts when they get really tired like the YZF250s.
I don't have enough data on the CRF250X to know for sure if the valve and seat material is exactly the same as that used in the 250R. Intial observations point in that direction but I'll reserve judgement till we get some additional time working with them. We are still waiting for pistons and rings for the 250X from Honda, but it appears they are the same as the 250R. As we get more time to work with these Eric and I will provide additional info.
Bottom line is, if you want XR reliability buy an XR. :) If you are willing to do additional maintenance in exchange for a LOT more performance from both the engine and the chassis then step right up and enjoy the four-stroke revolution. It's an amazing ride. :yeehaw:
a454elk
Mexicutioner
7,529
18
Mine has 2 rides after the break in stuff and it runs great. It is cold blooded, which is normal I believe but after that, it seems to run fine. I have the CA model obviously and it could use some more top end, maybe the White Brother's pipe I have coming will achieve that. The suspension is unbelievablely nice and plush at stock settings. Don't seem to find the need right now to change them, it jumps well and soaks up whoops and landins real nice. It doesn't have alot of wheel spin, seems to put the power to the ground. It handles better than the RM did and likes to use the low end torque to pull it through the tight trails, with no clutching. I've only found that the top end doesn't have the power like the bigger bore ones do but other than a flat out wire open run on a fire road, it holds its own. I'm 5'10" 180lbs and it works just fine for me. I'll post after I change out the pipe and have the air pump removed.
The filter panel on the left side comes in handy when you need to change it, no removing the seat. The electric start works just fine, my fingers really don't get in the way, just clutch in and go. If it's really a problem, you can bypass the clutch in deal with a change of the wires.
Elk- For you guys in California the 250x has a different carb and much different (i.e restrictive) cam timing than the 49 state 250x models. The 250R has much more appropriate cam timing for making horsepower.
California 250X cam specs
IVO TDC @ .040"
IVC 45 ABDC @ .040"
EVO 45º BBDC @ .040"
EVC TDC @ .040"
49 state 250X cam specs
IVO 10 BTDC @ .040"
IVC 40 ABDC @ .040"
EVO 40 BBDC @ .040"
EVC 10 ATDC @ .040"
250R all
IVO 15 BTDC @ .040"
IVC 50 ABDC @ .040"
EVO 50 BBDC @ .040"
EVC 20 ATDC @ .040"
Look closely and you'll see there is NO overlap on the California cam. :yikes:
Be prepared to have TTR 125s run around you with the stock spec CA cam. :bang:
Your money might be better spent getting Ol89r to swap cams for you, and helping you sort out the jetting. :cool:
a454elk
Mexicutioner
7,529
18
That's an idea, didn't know there was such a difference. I'll let it finish the break in process and look into the cam change and all. TTR!! Pfffffffffttttt! Only if AJ is riding it, and maybe Billy, I'll be damned if I let one of those pass me, whatever it takes!LOL Actually, I have a better chance if Billy is riding it, he'd go about 30 ft and KUNG POW!! Broken pieces all over the place.
With no overlap on the CA X there is no real opportunity for the scavenging effects of a good pipe to do their work. As a result there is very little to gain from a pipe other than a basic reduction in backpressure from an overly restrictive stock muffler core.
Flow at TDC during overlap is one of the real keys to making pipes and cams work together to produce real horsepower. No overlap equals NO JOY. :bang:
a454elk
Mexicutioner
7,529
18
damn the lack of overlap
The good news is, cams are fairly cheap and they are reeally easy to install in this engine. I'm going to talk to Tony Tice from Hot Cams and see what he has in store for the Junior CRF ;)
JasonJ
1,150
Rich, thanks for the info. I think Ill sit on the big blue WR another year and watch the Honda CRFX saga play out. Any word on the clutch issues I read about on TT? Looks like an additional center plate is needed to keep the clutch from bottoming out after minimal friction plate wear? If this is confirmed, it might be a good idea for you to drop the extra plate in when the clutch is new so it wears even Elk.
holeshot
Crazy Russian
1,822
I'm wondering which would work better in the X head - the 49 state cam or the R cam, since there's supposed to be differences between the R head and the X head. Or maybe the aftermarket will come out with a cam with specs between that of the R and 49 state X.
Another thought would be to port the X head instead of swapping it for the R head. Presumably, the X head would have more meat to work with than the R.
Whatever the case, I think I'll let Smelks X be the guinea piglet before I step up and buy one. :ride:
Tony Tice
40
I'm very interested in what's going on here
At least with the X "O" overlap camshaft anyway. How many people have had their valve covers off and checked their valve shimming? Or replaced rings? Or whatever, so that the cam is exposed?
Thanks Rich for e-mailing me. Seems that the X lacks some top end performance, eh? At least it has some good bottom end snap, right?! Has anyone had a tach on it or dynoed it yet? What's the torque curve look like? Ping Pong table? Let me know.
Tony
a454elk
Mexicutioner
7,529
18
The Ca X has good low end and mid torque/snap, it lacks on top end though. Sounds like the yzf/wrf differences in the past. Set it up like the R version and lose low end torque, leave it as is and keep low to mid and not have a top end hit. Guess it depends on the riding, tight single track seems to suit the stock X setup, so far. I'll have to wait and se how it plays out. If I really want the top end hit, I'll jump on the RM.
Rich Rohrich said:
Elk-
IVO TDC [at] .040"
IVC 45 ABDC [at] .040"
EVO 45º BBDC [at] .040"
EVC TDC [at] .040"
IVO 10 BTDC [at] .040"
IVC 40 ABDC [at] .040"
EVO 40 BBDC [at] .040"
EVC 10 ATDC [at] .040"
250R all
IVO 15 BTDC [at] .040"
IVC 50 ABDC [at] .040"
EVO 50 BBDC [at] .040"
EVC 20 ATDC [at] .040"
:ohmy: HIS MONEY??? What ya talkin about mister. :yikes:
Rich. My local cam grinder has one grind available for the 250X. Also fits the 250R.
In. .332 lift.
Ex. .325 lift.
In. 239 degrees duration @ .050.
Ex. 249 degrees duration @ .050.
In. O @ 12
In C @ 47
Ex O @ 49
Ex C @ 20
Checking @ .050.
I like Holesnots idea of using elks 250 for the guina piglet. :laugh:
Elk. Keep in mind that the more duration and overlap that a cam has, the harder the bike will be to ride in the tight stuff. It would be kinda like a RM 250 where ya gotta clutch it and rev it just to get off of a corner. Who the heck would want that??? :rotfl:
holeshot
Crazy Russian
1,822
cam stuff
Whoa... this may seem pretty obvious to all you four stroke experts, but people like me need some four stroke edumacation. :eek:
First off, lets be sure we're getting our terms right -
IVO TDC = Intake Valve Open at Top Dead Center (0 degrees)
IVC 45 ABDC = Intake Valve Closed at 45 degrees After Bottom Dead Center
EVO 45 BBDC = Exhaust Valve Open at 45 degrees Before Bottom Dead Center
EVC TDC = Exhaust Valve Closed at Top Dead Center (0 degrees)
All measured when the valve has lifted .040" off it's seat (I think).
If you look at the specs for the Ca X cam, you can easily calculate the duration for the intake -
0+180+45 = 225 degrees of duration.
And for the exhaust -
45+180+0 = 225 degrees of duration
I'm using 0 here, because the exhaust valve closes and the intake opens at TDC (0 degrees), hence the "no overlap". Overlap can be defined as the period (measured in degrees) when the Exhaust and Intake valves are open at the same time.
Same goes for the cam that Old 69'r posted,
The 239 degrees intake duration comes from
12+180+47 = 239
Exhaust duration -
49+180+20 = 249
If you look at 49 state cam, you can see that the Intake Valve Opens at 10 BTDC and the Exhaust Valve Closes 10 ATDC, giving 20 degrees of overlap (as opposed to 0 overlap for the Ca X cam)
Using the same method, 250R cam comes to 35 degrees of overlap.
No lifts have been posted for the Honda cams (it would be interesting to know).
Doing a search on the web resulted in opening another can of worms - there are things like ramps on either side of the lobe (I assume steeper ramps are beneficial to performance but are a lot harder on the valve train). There's also something called "lobe centers", but my head hurts too much to explore any further. :bang:
What does this have to do with twisting the throttle? Nothing. :joke:
Be sure to set me straight if I've stayed of course a bit.
Tony Tice
40
Edumacation? Bob Smith quote? Excellent Qs though.
In all reality, it does not have "0" overlap. It has 0 overlap at .040" lift though. All the peak lifts are 8mm, from what my source told me, for the 49 state X and the R. He didn't know for sure what CA X was.
Your descriptions of IVO, etc. are correct.
Cams have several portions to each lobe. The base circle (speaks for itself doesn't it?), opening and closing ramps (I'll explain in a moment), ramp faces (the steep portion of the lobe), Nose (the peak of the lobe).
Opening and closing ramps are (in laymen's terms) a slightly raised portion of the lobe before and after the ramp faces on either side of the base circle. These lift the valves off the seats and then sets them back down gently. Not getting the valve clearances set correctly, usually results in the valve lifter missing the opening and closing ramps. This damages the valve face when it contacts the seats and usually pounds the top of the valve stem along with the lifter and ramp face of the lobe. That is why it is very important on a modern, high rpm, 4 stroke engine to get the valve clearances set correctly. There are other implications as well but, for the time, always make sure you get the valves set right.
Lobe centerlines. This is a term that describes where the position of the cam lobes are in relation to the crank's position. Twin cam engines can have the advantage of being able to set the exhaust and intake lobe centers seperately.
On single cam engines, lobe centers are set and cannot be moved. By adjusting the intake lobe center, you also change the exhaust lobe center as well.
The lobe centers define the character of the engine's power delivery. I'll use a YZ450F for a description, if the lobe centers were adjustable anyway. The std L.C. is 103 for the exhaust, 110 for the intake.
Under normal circumstances, adjusting the exhaust several degrees either side of this setting will not change the way the engine feels. The power won't change, the delivery will stay the same.
Changing the intake timing a few degrees will change the character of the engine enough to feel the difference when riding and makes a big change on a dyno. It normally moves the power up or down the rpm range depending on whether you retard (move the lobes against the direction of crank rotation) or advance the L.C. It rarely changes the peak power unless you move it too far. It will also effect the over-rev power drop (the rpm after the peak power).
Typically, the power will fall off faster in the over-rev when you move the lobe centers together (advancing the intake lobes, not moving the exhaust, say 103 ex, 108 intake) but, it makes it's power earlier in the rpm range and peaks sooner, resulting in better engine acceleration and response.
Spreading the lobe centers (retarding the intake to 112, leaving the exhaust) results in more top end biased power and better over-rev but shortens the usable rpm range and softens the bottom end.
Hope that helped.
Tony
holeshot said:
Whoa..
Sounds like you got your terminolgy figured out pretty good Hogsnot.
Ramps on a cam have a lot to do with the type of lifter used. Depends on if it is a flat lifter (CRF-YZF cup style) or radiused rocker arm, (XR style) or a roller rocker arm, (CRF exhaust lifter style). And you are correct sir, the steeper the ramp the harder it is on the valve train. The angle on the ramp and the shape of the lobe determine how fast/slow the valve is opened/closed and how long the valve remains open.(Duration).
Lobe centers are used when timing cams. Since few cams time out to the specs that are given in the little sheet provided by the cam grinders, you have to find a happy medium. You can do this by using lobe centers.
To find the center of a cam lobe, in the case of the Exhaust cam that I listed, take the Opening figure of 49 degrees and subtract it from the Closing figure of 20 degrees and you will get 29 degrees. Add 180degrees to the 29 degrees and you get 209 degrees. Divide 209 degrees by 2 and you get 104.5 degrees center.
And, it has everything in the world to do with twisting the throttle. Too much overlap and the bike will be very hard to ride. It may have a tremendous amount of top end but no low end. The transition from low end to top end power will not be smooth, hence the term 'Coming on the cam'. Similar to a early style two stroke without powervalves, 'Coming on the pipe.'
Ok, now my head hurts. :laugh:
BTW. Tony, did not mean to mimic anything that you said in your post. Looks like we posted our response within three minutes of each other.
