hello everybody as you can see im new to the forum,and im glad they finally activated my membership.my nephew has traded a 2006 yamaha blaster for a 04 cr125r.the bike would not stay running when we went to do the trade so i said to my nephew are you willing to put 300 in the bike.he said yes so we left with it.
here is what the bike does;
*bought 5 plugs and it has fouled everyone of them
*wont start and if it does it just boggsout
*if i get it started it will run good reved full throtle but when back to mid bogg and try to die.
*i did a compression test and it looks like around 60lbs,so this is low should be around 160.
*so im tering it down now
heres what i found when i took topend off:
*carb has been cleaned by me all stock setting and jets in this bike.
*i removed the reed cage and they are fine cant see light through them at all no cracks good on these.
*while the reed cage was out i took my hand and pushed the kicker down and can hear compression leaking through the rings.
*removed head and it is so clean i can eat off it (no carbone)looks like sombody cleaned it.
*removed cylinder and piston and they looked real good to no gaulding or major damage at all.plating looks pretty good,piston skirts look very good.
*i took the old piston ring out and put it in the cylinder and checked the endgap on it.manual said max gap is .026 and i measured around .030 so ring is woreout for sure.
*rod and crank are fine
*took the cylinder to the local kawasaki dealership to have the cylinder miced.and he says it out of round by 2.5 thousands.
this is where im at on this thing right now,and could use some advice.my nephew is not going to race this bike just trail ride mostly and may hit a few jumps on the track once in awhile.
i found a guy that will put a sleave in the cylinder for 300 and it will have 3 or 4 bores after stb bore.im thinking this is the way to go since hes not racing it.if it gets messedup again just bore and go.i have researched on this forum and called to price the replating and it is going to run 200 just for the plating.the sleave guy is going to sleave it and supply namara piston kit with gaskets for 300 even.
can you guys give me some advice please this is the first bike i have messed with.i have rebuilt 400exs and blasters so i know some things.and im a great car and truck engine rebuilder.not bragging just letting you guys know my hands on experiance.
thanks killer454 :nod:
