I'm curious as to the reason nitrogen is used for shocks. Would oxygen perfom the same as nitrogen IF it were completly dry?
Regardless of wether or not you use air or nitrogen it wil not draw moisture from the oil. The gas is kept seperate from the oil by a rubber bladder. Unless the bladder fails the two never meet.Originally posted by Jaybird
If there is in fact moisture in the oil, why would it be different than sharing the space with nitrogen? Are you saying the "air" would draw out the moisture from the oil and the nitrogen won't?
