Regarding the oxygen concept. I assume the misunderstanding is someone using their oxy acetylene welding oxygen to pressurize the resivoir. This would be bad. Using compressed air (not oxygen) be it by a Fox or other pump or compressor if enough pressure, will work though nitrogen is better.
I am old and ran the Fox dual airs, in the manual fox said use a N2 tank or bicycle pump. As for all the MTB dampers I've done, I can use either N2 or pump air, most get air, as this is what the manuals recommend. Remember this is for MTB's and they typically won't get near as hot as a mc damper.
As an aircraft mechanic oxygen is considered different from air, we service the O2 from bottles, and service the tires and hydraulic accumulators and such with N2. The air is either ambient or bleed air. Unless you're British with pneumatics instead of hydraulics.
PK
PK
