This '90 200 has been sitting for the better part of the last 2 years exept for an occasional quick ride to make sure it still works. This weekend I noticed that the gearbox oil was milky. I immediately changed it but it is still being contaminated, either by leftovers or a continuing problem. It starts and runs great, by the way. No problems shifting. A good ride. The volume in the sight glass is normal. I would like to hope that the water pump seal is bad but I'm sure there could be other, more serious or likely causes like a head gasket or worse. What steps should be taken to identify the cause and could the oil just turn thin and milky from age and the gearbox just needs to be flushed out better before refilling?
thanks, .......Chris
