I have a 93 KDX 250 I am working on an oil leak at the drive shaft. I have searched all the past discussion about this problem and found all I need to know to fix it. My problem is I removed the sleeve and O ring and cleaned the lip seal to see if that stops the leak. In looking at the diagrams of the transmission assembly from the www.buykawasaki.com web site I noticed it shows 2 O rings. I only found one on my bike. I even looked up the diagram for a KDX200 it’s a little different but pretty much the same. It also shows 2 O rings the same part number. Dose anyone know if I need 2 O rings? Maybe that’s why it’s been leaking. Thanks for any response.
