Oil Plug is stripped, and will not back out...advice please.
hypermike
8
Well I went to change my gear oil, and found that my oil plug is stripped, and just turns and turns, and will not back out. Funny thing is that it's not leaking a drop of oil, but I know that there is probably a bunch of thread shavings in there by now, so I dare not ride it until this is fixed. I went down and bought a Helicoil for My 200 KX 250 ( 10mm x 1.25), but ran into a dead end trying to get that darn plug off. I took vice grips to it and still just spins. I am seriously considering just taking it down to the dealer and having them handle it. Anyone have any suggestions as to which to have them do? Helicoil vs tap to a slightly larger size? Which is the better option and which is more expensive to have done? How will they get the old bolt off? Is there a special tool that they use or do they drill it out? This problem just bugs me to death!! help. :|
mxmatthew
276
well I don't know what to do about getting the plug out but I just recently put a helicoil in my bike and it worked like a charm, I just used a regular drill. I got the advise to use a helicoil from a friend who drag races bikes and he says any part that they are constantly taking apart that is aluminum they put a helicoil in.
sick 96 250
1,207
have you tried and easy out bit? This happened before on one of my quads and the oil plug just kept turning. I drilled into it, used the biggest easy out type bit I could find and mocked up something so when I was turning the bit i was able to put more force on it pulling it outward and it finally caught and came out. Other than that I have no clue. I just got lucky I believe
crrod
87
If you have the room, you might be able to tap a small flat blade screw driver between the bolt and case to force it down a bit, then hold the screw driver while you try to wrench the bolt out.
hypermike
8
I tried the screwdriver deal, adn it was a no go. I haven't tried the easy out bit trick, but if that's what it takes then I'll just let my local cycle shop handle that. I'm not much of a machinist or a mechanic for that matter, so I'm one of the unfortunate ones that has to fork out the cash. I wish I had those skills, but what can you do. Some guys are just blessed with the skills I guess. I was just wondering what something like that would run me more or less, with the worst case scenario being that they have to drill the bolt out. best case being that can just easy out the bolt and tap to a slightly bigger size. I'd like to keep the bolt size OEM if I can, but if that's not the preferable option then I can live with the bigger plug.
sick 96 250
1,207
if you are going to get it worked on, your best bet is to see if you can find a friend or someone who knows a little about this stuff to do it. Maybe even a local member here will help ya, who knows, but i will almost gaurentee a dealer will really screw you on the deal for something that will prob take them 5 min to do with the right tools. At least the dealers near me would, maybe you will be lucky
mtk
1,409
Prying on the cases with a screwdriver is a sure way to screw them up.
crrod
87
I said small flat blade screw driver. Using common sense with it, is well.... just common sense.
hypermike
8
Yeah, as soon as I saw the washer and case start to scar a bit, I stopped that. The metal is just too soft to get any real leverage without damaging it. I am just going to have to get it to the service shop. The good thing is that my Bro in law bought two Quads from this Yamaha dealership and he owns a truck lift shop, so they all know him and they just changed a tube for me and they gave me a great deal. They said, we should charge you more for bringing a green machine in here, but since you're jerry's bro in law.......they said in a joking manner. I told them my bro in law said they were the bomb for service so that's good enough for me. They liked that. A little ass kissing sometimes goes a ways when it comes to proud machanics. :nod: So I don't think I'll get screwed, as I am lucky enough to have a connection, thank goodness.
I did a search and it seems this is all too common of a problem, judging from the amount of posts that I found on this and it seems the main culprit is that people don't realize that although "righty-tighty" and "lefty lucy" are correct ,you have to realize that you are doing it upside down, so it seems like you are loosening the plug, when in reality, you are tightening it because you are facing the plug from the bottom. It can be quite a costly mistake and lesson for those who don't realize this, and are limited in their mechanical knowledge, like me. I hope somebody reads this and learns from it, then it will at least something good will come of this. Thank you to those who took the time to respond. I am new here, but not for long. I love this place for educating myself on the do's and don'ts of the MX world. :cool:
crrod
87
First time I went to change my tranny fluid on my CR125, I had to get a two foot cheater on my ratchet to get the drain plug out, and it had a crush washer on it! I just knew I was going to see the case threads on the bolt, but that wasn't the case (lucky for me). I installed the drain plug with a rubber O-ring and haven't have any trouble since (along with not use a 3/4" impact to install it:-))
My oil level bolt is striped on the KTM, I hope the drain bolt isn't!
mtk
1,409
Swapping out the factory metal washer for a rubber O-ring is a bad idea.
Just because it hasn't vibrated out yet doesn't mean that it won't.
Assemble it the way the factory designed it, using a new washer, and you won't have any problems.
hypermike
8
Well I think I'll just go with a brand new magnetic tip plug and new washer. Interestingly enough, after making few calls today just to see what I was looking at more or less, the local cycle shop (mom and pop type) said "well at 70 dollars and hour with a one hour minimum, it sounds like you might be looking at 2 hours plus parts." :yikes: Parts? What parts? A plug and washer and a helicoil? It might not even need a new plug. 2 hours to get a plug out and retap and insert a helicoil? Are they charging for the drying time of the loc-tight? :whoa: The second call was to the Kawaski dealer, who said I was looking at about 70 to 100 bucks, and that he would retap to one size larger, and that he's not a big fan of helicoil, for reasons that have been beaten like a dead horse here,and that it would be a week before he could look at it. Finally the third call I made to the Yamaha shop where I have my connection through a bro in law. He said "sure, bring it on down and we'll take care of it for ya in a jiff." I asked him what he prefers, and he said he was going to helicoil it and that he has done this to alot of bike plugs and not a one of them have ever been back with problems. He said if it's done right, there's no reason to have to tap to larger size and reduce the material on your case. So you see, three different "pros" and 2 different opinions. Man am I glad I have a connection at a dealer shop, or else I have a feeling I would be paying way more than I should! Sounds like this is pretty common in the mechanic industry, but what can you do if you are over a barrel? :think:
Chili
Apr 9, 2002
8,062
17
Me and my ham fists stripped out the drain plug on my son's KX80 a few years ago. It was repaired with a helicoil and I found it would weep a little oil. I started wrapping the plug threads with teflon tape and made a bunch of very hard rubber washers and it was good for 2 more seasons for us with no problems. The kid that bought it just sold it after 3 years of use as well.
hypermike
8
Well, just dropped my bike off this afternoon, and the head mechanic told me he has had good success with helicoils, and that if it leaks he will do it over free of charge until he gets it right, or if necessary tap it up to the next size but that he's never had to do that yet. Guess he was giving me his guarantee that it would work. :cool: It's hard to argue with that kind of service. I think I've found my new permanent bike service guys. I feel pretty lucky right about now. :nod:
m14cus
5
I've stripped my threads too.
I have an 02 CR125 what size heli kit do I need ?
M12 x1.5, m14x1.25 ?
I don't want to buy the wrong size
cheers
