I pulled the top end off today to rebuild. Just got the 94 CR250 a few days ago. First time touching this bike, or any two stroke in a long time for me. I have a repair manual on the way, but don't have it yet. Drained what I thought was most of the antifreeze, but I guess not enough. :bang: When I broke base gasket a bit went into the crank case. I flipped the bike completely over and let it drain and drip for a while to get it all out. Is this going to cause a problem? I am planning to fire up the compressor and dry it out completely. Should I do something more? Should I pour a bit of oil in there on the berarings? Rinse it out with solvent? I get the feeling that when I flash the bike back up it's all going to dry up and any moisture will be blown right out the exhaust pipe. Seeing as the bearings are caged ball bearings I see little if any problem with the A/F getting in there. (Unlike your automobile crank bearings, the babbit gets broken down.)
Your comments on this are appreciated. Now I know better for next time.
Keith
Keith
