yz250flash
- Aug 8, 2003
- 150
- 0
This is for a 1996 200.
I know the manual gives a range of 0.079 - 0.089 mm but I have read on a couple of post that people are running tighter tolerances than this. What are you guys running if not going by the manuals specs?
I had my cylinder re-measured this morning and came up with a measurement of 66.04 top and bottom, side to side (so it is still round). What would be the best piston size for me?
Using the manual's tolerances if I went with a "C" piston (65.96mm) I would be at the lower range of 0.080.
My cylinder is actually a "B" but if I used that piston (65.95mm) then I would be at the top of the tolerance.
Here is a list of the piston sizes from Pro-x and Wiseco:
Pro-X:
A = 65.940 mm
B = 65.950
C = 65.960
D = 65.970
Wisco: One standard size of 66.000 mm
Your help and advice is appreciated.
Pro-X:
A = 65.940 mm
B = 65.950
C = 65.960
D = 65.970
