Pds 1-250
Does anyone know what this spring rate is? I'm trying to set my sag but can't get more than 65mm and the only numbers I see on the spring is 1-250
marcusgunby
Lifetime Sponsor
jeff The spring is a PDS1-250, 250 is the length in mm,1 is the rate which is 7-9kg/mm.Std is a 2, so it should be ok if you are light, with your sag numbers you must be very light-post back your weight and we will see whats wrong.
Marcus
I'm 150lbs approx. with out gear.
I think I know what I did wrong, I was using the difference between free sag and loaded where as I should have used the difference between unloaded (on the stand) and loaded. I'm about to go at it again and I'll update.
Yep, that did it. I feel better now.:)
