Recently picked up a 92 RMX250, very clean and well maintained. Ran great until the first outing. First, the idle screw did not affect the idle. Then, it started bogging at low speeds and dying when stopped. Suddenly it died, wouldn’t start. Dumped lots of fuel from overflow when trying to start. Went through carb three times, cleaned, adjusted floats, put in stock main jet, all looks good. Still dumps fuel after few kicks. Then found that the spark plug was shorted out. New one and it started right up. Thought it was fixed. Went riding, gas still dripping out overflow, won’t idle right (this may be due to the cable, though), started bogging, eventually died, won’t start, lots of fuel around the carb and the overflow. Took plug out, moderate to high carbon, but very oily and wet. Cleaned very well, put back in and it started!! Though not running well. Very weak spark. Old plug still won’t work. Other night, I realized that the vent house from the gas cap was stuck down the hole in the steering column and the column was full of water. At this point, it could be pressurized gas tank blowing fuel past carb, some unseen thing in the carb is flooding engine (only if I’m blind!!), or the spark is not enough to burn all fuel… or not enough air, but that’s doesn’t seem likely. Engine getting way to much fuel, but somehow plug is fouling and shorting out. Can too much fuel short the plug? Any ideas or suggestions or has someone experienced this before? Thanks!!
