Power friggin' valve? FOLLOW UP
I ride an '80 KDX175, '78 Yamaha IT400, '75 Yamaha MX400B and have a '79 Yamaha MX175 for my daughter to ride.
My best friend has a couple of mid '80's Honda XR200s that he and his son have been riding, but last weekend he picked up an '86 KDX200 for $350. It runs, but needed a few things right away, and he now has about $500 in it. He thought I would be his 2-stroke guru to get it all dialed in, so I stopped by yesterday to look it over.
1986 had much more technology than I am experienced with working on! I understand the basic old 2-stroke, piston port, air cooled bikes, and this one is air cooled --- but it already has systems I don't have a clue about. On the right side of the cylinder there is a 'push rod' of some sort, in a rubber sleeve, which seems to push a lever into a wheel (the lever and wheel are in a cover on the side of the jug), and on the left side is another cover that I haven't taken off.
I know that some Kaws were rotary valve, and am wondering if this one is, or if this is the 'power valve' that I've seen posts here about. I figured the power valve was something on newer, water cooled bikes, so have always skipped those posts, as they didn't apply to my bikes. On the other hand, if it is a rotary valve, I don't really understand how that would work on a 2-stroke either. Does it somehow use a valve instead of transfer ports for intake and exhaust?
Could someone give me a basic rundown on what a power valve is and does, and how a rotary valve functions in a 2-stroke? If you could kind of compare it to the piston port systems I'm familiar with it would help.
Also, he has the carb torn down soaking in Berryman's. He called me a little while ago to say that there is only one adjustment screw on that carb --- the idle speed screw (which happens to be turned all the way in) ... no pilot screw, no air screw. Doesn't the thing have any adjustments?
I told him to buy a Clymer's, but no one has one locally in stock. Any help you can give me is ap0.preciated.
