2-Strokes 4-ever said:It doesn't overheat or develop a high idle when good and warmed up does it? (signs of too lean)
schmanman said:my yz 175 bogs before it is all warmed up, after the engine is hot, the bike runs perfect.
I do not mind this, I am just curious as to why this might be?
it sparked my curiosity, and where better to ask than here!
Your friends CR is jetted to run optimally; your RM is jetted rich, so it provides plenty of fuel for your cold engine. I'm sure you do not have to use your choke as much as your friend, either.RM85rider123 said:my friends CR does that. My RM doesn't. weird.
SpDyKen said:Your friends CR is jetted to run optimally; your RM is jetted rich, so it provides plenty of fuel for your cold engine. I'm sure you do not have to use your choke as much as your friend, either.
You might want to read up on the various jetting threads first, instead.schmanman said:yea, I think I might also mess with my main jet, since it's either rich or too lean.
Go to the advanced search on jetting and reading your plug. Read them twice if it takes it. That statement you posted told it all.schmanman said:yea, I think I might also mess with my main jet, since it's either rich or too lean.
So why would we answer your questions if you are not interested in listening to our advice?schmanman said:the whole range of throttle, previous to my unifilter, was fine, except wot.
so whay would I change everything else?
