So I'm transitioning from someone who only thought of rich/lean to do with the fuel/oil mixture to someone who is now trying to understand the process as a whole.
I'm looking for people to set me straight and also offer their opinion, but as of now, i understand that premix = the fuel/oil mixture. And when talking about premix, a rich mixture is one that contains a higher portion of oil.
So the less fuel you add to a given part of oil will result in a rich premix mixture (like 20:1). But the more fuel you add will result in a lean premix mixture (like 50:1)
However, the carb involves an air/fuel ratio. So what is considered to be a rich premix (20:1) actually translates into a lean air/fuel mixture since there is less fuel contained in the premix.
And it seems like you can somewhat compensate for improper jetting by adjusting the premix, but only within a small parameter. Since a WAY WAY lean premix will not contain enough oil to effectively lubricate the crank. And on the other hand, a way rich premix will just oil foul the plug quickly.
So what is important to focus on. Do you play with premix to try and get an ideal air/fuel ratio in the carb? Or do you jet the carb to get an ideal air/fuel ratio and then run a set premix ratio? And how important is the premix ratio? Seems like premix won't give you a whole lot of flexibility so why bother worrying about what exact ratio you are at?
Just wondering because I'm hearing people talk about rich and lean concerning premix and air/fuel and it gets so damn confusing I feel like I'm worse off after having read it all.
Micah
Micah
