Hi all!
Long time since I've been here. The bikes didn't make it out of the shed for over two years, so decided to sell a couple.
I have a '79 MX175 that I removed the autolube from and ran premix. I pulled it out, cleaned the carb, put in a 32:1 Bell Ray premix and it started right up.
I dialed in the idle and pilot and had it running quite good, it seemed, so I listed it for sale. Then I connected the airbox boot, which I hadn't gotten around to. I also mixed up some other premix at 32:1 with Klotz Techniplate right about that time ---- one or the other created rich running conditions, fouled plugs, and trouble. Then we had a brief monsoon season so I didn't mess with it, and got busy with other things.
Last week I started wondering if maybe my premix had been more the problem than the airbox, so mixed some at 20:1 with the Klotz, which is close to the ratio the autolube would have injected oil --- and the old school Klotz could have made me run richer than the more modern Bell Ray.
Suddenly though, no spark! --- but I noticed, when I kicked it, that drops of gas seemed to be coming from the bottom of the magneto cover. I pulled it off, and sho' 'nuff, it was full of premix --- so I was getting no primary spark to the CDI.
I sprayed some electical parts cleaner in there, but still don't have spark --- probably will have to pull the magneto cover/flywheel and check coil resistance, but don't even want to bother if I have to put much money into the thing. I'll be lucky to get $500 for the bike with it running good.
My kickstand is bent, so the bike lays over pretty far when parked. The petcock got left open after I showed it to a potential buyer, and I'm assuming gas was flowing through the carb while it sat around for a couple of weeks.
I just don't know why it ended up in the magneto area.
Any ideas?
Should I just rry to get $200 for it, as is, and say good ridance?
Any ideas?
