Primary Gear Possibly Worn Among other things. 95kx265
joe265
42
In need of a little advise. :bang: I put up a thread a while back about engine/clutch noise and i think i may have stumbled onto something not so good that may be the cause. I need to know if the primary drive gear on the crank which drives the clutch basket is suppose to have any side to side or up and down movement and have any movement when turning it back and forth. I also am able to move my outer clutch basket side to side when puting opposing pressure from left to right pushing and pulling with each hand, :coocoo: and when i grab the inner basket it almost feels just like a car wheel that hasn't been tightend down all the way. In my oppinion this sounds pretty bad. My outer basket is severly notched from the clutch discs and plates and i also found water getting in my tranny case through clutch lever on the motor. Now i know why my sight glass allways turns white when i ride :| Does this sound like major trouble with worn internal and external parts? Any help from kawi owners would be greatly appriciated.........Thanks
vasvar82
12
A good thing to do is replacing the clutch roller bearing(s) and spacer immediatly! Eventually you'll have to replace the outer basket as well...
