puggerton03
- Jul 19, 2010
- 11
- 0
I just picked up a 91 CR250. It has a PSI Racing pipe on it. Does anyone have any info on that pipe? I ordered some Boyesen power reeds for it and went to put them in only to find out that the holes didnt line up on the reed block. I had to elongate the 2 outside holes on the reeds to make them fit. It looks like someone put a different bike's reed block on it. They also cut off the "stuffers" on the rubber carb boot and put some sort of aftermarket stuffer up inside the reed cage. The problem is that there is a little tiny gap on both sides of the reeds. Do you think this would cause a bad idle and low-end? Right now I have to adjust the slide up a little to get it to idle.
