We have a 2004 PW50 and its throttle limiting screw doesn't seem to do much anymore. Either the screw is in so far that the bike will barely move, or the screw falls out if you try to adjust it to go a little faster. The bike won't even move on level ground in our backyard because of the screw, and if I adjust the screw so that the bike will move, the screw falls out and the bike speeds up quickly...not good. (Throttle limiting screw is new.)
The bike runs well, and I have long since removed the washer from the exhaust pipe.
Should I replace the grip assembly on the chance that fresh threads (in the hole where the screw goes) will allow a better bite from the screw? Is there anything else I've missed? Anything else I can try?
Thanks for any help you can provide!
