brlatm
17
I have recently moved to about 5000' elevation and installed a fmf pipe silencer and changed the clutch springs and rear gearing on my sons pw50. I adjusted the idle screw and air intake but it seems to chopout at full throttle wide open on the test stand. I put a 67.5 main and open the airbox up with a different filter plus 1" air box filters. I am running Motul for the oil injection. He has a race coming up in 2 weeks any ideas to clear up the topend matter would be appreciated.
Vic
***** freak.
4,008
How does it run with the rider on it?
FruDaddy
2,854
Try moving the needle clip up a notch and/or leaning the main out a bit. I don't remember what the stock main is, but I think it was a 65, if so, you should probably go to a 60. If it was a 70, the you need a 65. Also, a fouled plug can make it run like crap.
Vic
***** freak.
4,008
Sounds more like you need to go richer, to me. Changing the needle position won't affect WOT performance, except, possibly, if you drop it too far.
brlatm
17
I am going to try some plug test if the weather clears up and see what the colors are could a slight crack in the oil injection hose going into the carb also be causing the problem ie ( air sucking in)???
MikeeeP
61
You sure it's not your rev limiter? When you put the pipe on and open the airbox it revs much quicker. When the rev limiter kicks in it becomes MUCH more noticable. It will run and then break up and if you keep holding it on, it might clear back out for a moment and then start breaking up again. I've seen a lot of people think their bikes were running terrible after they modify them, but in reality they were running stronger and the rev limiter was tricking them into thinking they were running poorly. Hope that's your case. Oh and if you're sucking air, it will definately pop!
