- Jun 29, 2005
- 443
- 0
Well I finally broke down and installed the Boyeson RAD valve in my CR. I was really hesitant because the CR was running great, but you never know till you try. I have always found the RAD valve to be more responsive off the bottom than the Mototassinari ( V-Force ) valve - and the Mototassinari stronger on top. That does not seem to be the case with the new V-Force3. It worked better than the RAD valve everywhere. The old style V-Force valves I have used in the past do not have the contoured throat the new 3 does, I guess this accounts for the increased response off the bottom. If you looking at reed options on the '05-'06 I'd recommend you go with the V-Force 3
