CR69r
21
my bike seems to be jetted as good as i can get it. the general appearance of all surfaces are perfect chocolate brown. >>>with the exception of the tip of the electrode, which is white. i'm only talking about the tip here - an area the size of a pinhead.
i'm thinking this is a problem for 2 reasons:
1) i've never had a plug look like this
2) I"m getting some kind of pinging at mid throttle in third
gear.
the sound is almost like one of those mexican rattles, but if the rattle only contained 2 or 3 pebbles. not very loud. i know what detonation from not enough octane is, and this isn't it.
some of you will be quick to say that since we are talking about mid throttle its the needle. if that were the case the L shaped arm of the plug should be white or grey. which it is not. the bike is at the line of blubbering so i know i can't go any richer. i was told by a factory mechanic once that this arm is the indicator of the needle, while the fat ceramic insulator that goes up into the plug is the main. i can't remember how to read the pilot from the plug.
the bike in question is a stock '03 cr250. (vforce and pc pipe are the only mods). i run pump 91 octane with klotz octane boost to bump it up around 94. i'm at sea level, and presently jet with 30 pilot, 70 needle in 2nd clip, and 420 main.
the only alternatives i haven't tried are the pilot jet and plug heat range (i'm using a br8eg).
appreciate the input guys!
bclapham
4,340
them CRs are a pain to carb up, you can have them rich and still ping, lots of people are running the carb from the 2000cr250!!!- a freind of mine has the same bike and mods, he is a fast dude with a lot of experience, after hours of chain adjustments for "some funny noise" i rode it and realised the ping was there- i think we tuned it out with 1 richer on the clip and turn the airscrew out. i daren't look at the plug!
