GTiR_pilot
- Dec 21, 2007
- 6
- 0
Hi i URGENTLY need help to try to fix the rear brake on my 2007 Yamaha YZ250F. My problem is that when i lightly pump the rear brake lever (only pushing it to halfway through the stroke) the pressure inside the brake lines builds up, effectively dragging the rear disc. Sometimes to the point of a complete grab when you pump it 3 or 4 times. But when you press down hard on the lever it will brake normally and release normally but when you go to apply the brakes again there is no pressure at all on the lever until you pump it lightly again. I have a very important race i need to attend on the 29th so don't have very much time to get this sorted as parts shops will be closed during xmas and i'm stumped to what the cause of this problem may be. Any help will be HUGELY appreciated.
