hi there guys, i need some help in changing my rear wheel bearings on my 1999 kx125, the bearing setup is two on the sprocket side and one on the brake side, i have gone through some old posts and guys say that they use socket extensions and things like that to bash out the bearings from the inside out, but on my rear hub you cant do that, as there is nothing to hit out, what i mean is that there is a spacer in between the bearings inside the hub, and the is nothing to grip onto to push the bearings out, when you look through the the hub its just straight through like your looking down a pipe, there are no ridges or anything, i have got a part diagram from kawasaki.com that shows what im saying clearly but i cant post attachments.
any help will be appreciated.
http://www.kawasaki.com/SITE/VIVehi...odelYear=1999&ModelCode=KX125L1&SHOWVEHTABS=1
if you use this above link then click on rear hub you will see what i mean.
