It sound the same after rebuilding top end/power valve. Under power It sounds like the main drive gear is stripped. After researching, could be either gear is stripped in which case I would see gear parts in engine oil. Or secondary power valve shaft nut to tight. Upon reassembly, I did feel some resistance while manually operating valve. Any input? Is there an easy test to check proper operation of valve.
If drive gear is culprit, is this a tough or easy repair? New gasket set required for bottom end? Clutch removal?
