Does anyone have an idea how many gaskets you would need if you were going to stack them to use as spacers,in order to make a difference in your bottom end? Also about what is the thickness of the metal reed spacers?
Honestly... I couldn't tell a difference either way with the reed spacer. I didn't use it for long.
Now I run a Vforce reed cage - and the cage itself is thicker than the stock block... so it's kinda like a little spacer/reed cage all in one. I can say for sure that the Vforce has helped the bottom end/throttle response on my YZ (I have the reeds set at the low tension setting).
If your bike is new you can get Boyesen's latest; it's what you want! If your bike isn't new you can get the Rad Valve for your model...They work great for the guy who wants to smooth out and lengthen his power delivery. Your bike will chug with one of these; and pull harder on top.
