OK, I'm replacing my right side crank seal on my 1980 RM250 because the bike couldn't go more than 20 minutes without fouling a plug and the jetting was actually a bit lean. Leakdown test showed a bit too fast of a pressure loss from 5 psi.
Anyway, the manual shows the seal with the open side facing the crank. When I got in there, the open side faces the crankshaft gear. Which is right? I know fork seals have the open side on the oil side, so maybe this is right, but I want to make sure before I put this in. Maybe it was installed wrong and that's why it is leaking.
So, Concave side faces inboard or outboard??
Please help if you know!
