Maybe someone can help me think this through. I have a 1982 RM465. When I bought it the man said it had a fresh top end and it just needed some TLC. Yea right, got it home did a compression check and it was 90psi. Pulled the jug and was not supprised to find a cracked piston, worn rings and a little scaring on the walls just to the right of the exhaust port. After calling all over the USA all I could find was a stock piston kit. Honed the cylinder and the new Wiseco piston was within specs. Put it all back together and it started on the 3rd kick. My question is, Wiseco has dropped this item from their catalog and has no more. I called them and asked if a Suz LTR500 piston would work. The guy said if you add a 5mm spacer on the base and 2 head gaskets it would work providing the rings didn't shoot out the transfer port because the pins are in the wrong spot.
Is there any piston in production that will fit this engine with or without mods? The bike is fine now but later I'll need a backup.
