'00kx250spode
- Oct 21, 2000
- 197
- 0
I just replaced every bearing on my 2000 KX310. It really wasn't too difficult and I learned quite a bit.
I'm having a problem with the 2 bearings that go in the top hole of the rocker arm (the hole that connects to the frame). The problem is that I can't get the sleeve to go in. It's just too tight.
The hole below that one (linkage hole) uses the same bearings and same diameter sleeve and that one slides in and out easily.
Did I smash the bearings or something? I've ordered new bearings and seals and I'm going to have to do this hole over. Any ideas where I went wrong or suggestions for doing it right this time?
Thanks!
Thanks!
