Heartattack_3
12
I am building a 1995 Yz250 I ordered a rod kit (could not find a complete assembly discontinued so they say) took it to the cycle shop and they tell me the rod is to short the vin # showed it to be a 1995 but I was wondering if there was any way to tell if the motor might have been swapped for another year. or if anyone could tell me what the specs for that year crank should be. thanks
Motor # 4MX-008399
Farmer John
T.C.F.<br>(tire changin' fool)
1,993
7
Many people put GYTR "long rod" kit in the 95 yz250's.
Is there a 5mm alloy plate under your cylinder?
Heartattack_3
12
Yes there is a plate under the cylinder. also I noticed that not only the main bearring was bad but the Piston had part of the skirt broke and the rod was bent.
mideastrider
827
How's the cylinder and head look after digesting the piston skirt.
Farmer John
1,993
7
You can go back to the stock size rod by leaving the plate out.
Heartattack_3
12
Well the head and cylinder looks good and Iam going to lightly hone it and put a new piston and rings. How much of a performance loss should i expect.
Farmer John
1,993
7
What the long rod kit did was was allow the bike to be smoother thru the mid. The bike shouldn't loose any power, it should be more abrupt in the delivery of that power.
The long rod kit did not change the length of stroke. What it changed was the angle of the rod at mid stroke. By lessening this angle the engine responded to changed throttle positions better.
