brentw
16
My 97' rt-180, after a year of not being cranked, ceases to start. I decide to drain the gas and put some new in it. After disconnecting the line after the fuel filter I did not get any gas flow (made sure the fuel cockpit said ON). So I decided to unscrew the fuel cockpit from my gas tank, and vualla, the gas started to pour out. After closely inspecting my fuel cockpit, I noticed it was all gumbed up to hell, as well as my fuel filter. I used degreaser to clean both, but it did little to help the situation. The top of the fuel cockpit had this screen-type filter, which I just ripped off because I couldnt get it clean enough. Should I just order a new fuel cockpit and gas filter? And if so what websites do you guys recommend I use?
YZ165
YZabian
May 4, 2004
2,431
I'd order a new filter and a rebuild kit for the fuel "petcock". K & L Supply has the kits for less than $20. Good luck, YZ165
Chili
Apr 9, 2002
8,062
17
You should be able to get them clean with a solvent of some sorts. If you decide to order a new one you'll have an easier time if you tell them you need a petcock instead of a cockpit :)
brentw
16
Here's a picture of the petcock:
http://photobucket.com/albums/y151/brentw/rsx-s/?action=view&current=100_1208.jpg
There was this wire-laced filter that was maybe an inch long I tore off, does that matter?
Sorry, the manual called it a fuel c0ck. :coocoo:
Also, should I probably clean out the carb? Trying to clean out the petcock is the first automotive thing I've done in my life, so would you guys recommend I try to take the carb apart and clean it? Or get someone to help me.
Chili
Apr 9, 2002
8,062
17
Taking the carb apart isn't rocket science, if you have the manual I'd have a go at it alone. The wire filter was there to keep crap from getting further into the fuel system. As YZ165 suggested I'd get a kit to rebuild the petcock.
brentw
16
Know where I could get an online repair manual, or just a diagram of the carb itself?
I hate to keep asking questions..I have been searching but I cant find the information I need.
